[Ta...] Posted 29 minutes ago Share Posted 29 minutes ago Could anyone help me with the scan tilting while creating interactively measurements, and what is causing this to happen? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/ Share on other sites More sharing options...
[Ma...] Posted 15 minutes ago Share Posted 15 minutes ago Just a question - is that from scanbox? Are you using a fixture with known ref. points and CAD model shown is from that fixture? I think it's called ref. frames. If for 2nd q is YES, then i think due low contrast for ref. points it can identify only a few of them so it may not correctly identify exact position on frame. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158610 Share on other sites More sharing options...
[Ri...] Posted 15 minutes ago Share Posted 15 minutes ago I'm not a VMR expert, but it just looks like the mesh and model are not aligned. Do you have an active alignment set? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158612 Share on other sites More sharing options...
