[Ta...] Posted 6 hours ago Share Posted 6 hours ago Could anyone help me with the scan tilting while creating interactively measurements, and what is causing this to happen? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/ Share on other sites More sharing options...
[Ma...] Posted 5 hours ago Share Posted 5 hours ago Just a question - is that from scanbox? Are you using a fixture with known ref. points and CAD model shown is from that fixture? I think it's called ref. frames. If for 2nd q is YES, then i think due low contrast for ref. points it can identify only a few of them so it may not correctly identify exact position on frame. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158610 Share on other sites More sharing options...
[Ri...] Posted 5 hours ago Share Posted 5 hours ago I'm not a VMR expert, but it just looks like the mesh and model are not aligned. Do you have an active alignment set? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158612 Share on other sites More sharing options...
[Ta...] Posted 5 hours ago Author Share Posted 5 hours ago I have a pre alignment and Alignment by geometric elements, or do you mean when i transform measuring object to fixture? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158618 Share on other sites More sharing options...
[Ta...] Posted 5 hours ago Author Share Posted 5 hours ago Yes it is a scanbox Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158624 Share on other sites More sharing options...
[Ta...] Posted 5 hours ago Author Share Posted 5 hours ago Here are the premeasured reference points Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158630 Share on other sites More sharing options...
[Ma...] Posted 3 hours ago Share Posted 3 hours ago I don't see any CAD model used as fixture. When i was making one i scanned points, made an alignment via CAD model, then exported those points into something similar what you have. Then i was applying this file and CAD model as fixture, then it was showing correctly. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158636 Share on other sites More sharing options...
[Ta...] Posted 1 hour ago Author Share Posted 1 hour ago So something like this? When i made the cad a fixture it removes it from the Part section where i made all my geometry off. Clearly im not doing stuff correctly. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158638 Share on other sites More sharing options...
[Ma...] Posted 47 minutes ago Share Posted 47 minutes ago What CAD model is your fixture? You should have only one. Then if you have model of scanned part, then it should be in "Part" section - not "Meas. enviroment" Also your points seems to be off your CAD frame. I think i would start over by clearing all and firstly identify ref. frame, then CAD frame as fixture. Then CAD model of a part. If CAD model of frame has same origin and alignment as ref. points, then it should match and you should see imidiate actual orientation in acquisition tab ( image of barcode on the left ) Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158640 Share on other sites More sharing options...
