[Ta...] Posted Wednesday at 03:21 PM Share Posted Wednesday at 03:21 PM Could anyone help me with the scan tilting while creating interactively measurements, and what is causing this to happen? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/ Share on other sites More sharing options...
[Ma...] Posted Wednesday at 03:35 PM Share Posted Wednesday at 03:35 PM Just a question - is that from scanbox? Are you using a fixture with known ref. points and CAD model shown is from that fixture? I think it's called ref. frames. If for 2nd q is YES, then i think due low contrast for ref. points it can identify only a few of them so it may not correctly identify exact position on frame. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158610 Share on other sites More sharing options...
[Ri...] Posted Wednesday at 03:35 PM Share Posted Wednesday at 03:35 PM I'm not a VMR expert, but it just looks like the mesh and model are not aligned. Do you have an active alignment set? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158612 Share on other sites More sharing options...
[Ta...] Posted Wednesday at 04:07 PM Author Share Posted Wednesday at 04:07 PM I have a pre alignment and Alignment by geometric elements, or do you mean when i transform measuring object to fixture? Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158618 Share on other sites More sharing options...
[Ta...] Posted Wednesday at 04:10 PM Author Share Posted Wednesday at 04:10 PM Yes it is a scanbox Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158624 Share on other sites More sharing options...
[Ta...] Posted Wednesday at 04:14 PM Author Share Posted Wednesday at 04:14 PM Here are the premeasured reference points Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158630 Share on other sites More sharing options...
[Ma...] Posted Wednesday at 06:02 PM Share Posted Wednesday at 06:02 PM I don't see any CAD model used as fixture. When i was making one i scanned points, made an alignment via CAD model, then exported those points into something similar what you have. Then i was applying this file and CAD model as fixture, then it was showing correctly. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158636 Share on other sites More sharing options...
[Ta...] Posted Wednesday at 07:33 PM Author Share Posted Wednesday at 07:33 PM So something like this? When i made the cad a fixture it removes it from the Part section where i made all my geometry off. Clearly im not doing stuff correctly. Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158638 Share on other sites More sharing options...
[Ma...] Posted Wednesday at 08:42 PM Share Posted Wednesday at 08:42 PM What CAD model is your fixture? You should have only one. Then if you have model of scanned part, then it should be in "Part" section - not "Meas. enviroment" Also your points seems to be off your CAD frame. I think i would start over by clearing all and firstly identify ref. frame, then CAD frame as fixture. Then CAD model of a part. If CAD model of frame has same origin and alignment as ref. points, then it should match and you should see imidiate actual orientation in acquisition tab ( image of barcode on the left ) Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158640 Share on other sites More sharing options...
[Na...] Posted 7 hours ago Share Posted 7 hours ago Hello, this looks like the measuring setup is not calibrated, meaning the virtual setup does not represent the real world. Either the virtual placement is off, or the real world fixture and part is placed tilted. ZEISS Quality Tech Guide It is also possible, that the alignment is off for some reason - could also be a wrong positioning of the CAD. Generally, the CAD of the measuring object is separate from the CAD of the fixture. The fixture can/should be avoided during scanning by using a restricted scanning area. This also depends on the measuring setup, which "tells" the software where the real world elements are in the scanbox. I think it is best to show this project to your local support. The measuring setup is also used for collision checks, so it's important that it is correctly set up. Nanno Link to comment https://qualityforum.zeiss.com/topic/27928-measurement-and-scan/#findComment-158654 Share on other sites More sharing options...
