Large scale photogrammetry projects
I've a large photogrammetry and scanning task upcoming and wanted to get views on the size of coded targets that people use with there Tritop systems?
  • 2 weeks later...
Hello Mr. Mason,
this is difficult to answer, because it depends on the focus distance, lens and resolution of your tritop system:
Simple answer: Just get sure that, the diameter of the un/coded points is about 10 pixels. Take one image at
a meaningful distance of your part and check the pixel-diameter of your points.
Then adjust the focus distance or use larger/smaller points.
What about the size of your part? What diameters of points are available at your site?
Best regards,
Jens Heidler
