hard to catch points when right angle has radius
Hello
You can catch a Theoretical Edge point created by the intersection of two lines or from the intersection of a line with a circle on a curved surface and then project this point to your scan but from what I see here is that you do not have a good definition of the form that you are scanning
The 90° angle/straight corner is hard to obtain not to say impossible to acquirer but you can get an approximated value to the real situation but you need to be more precise on you digitalization to have a good value
