[博文...] Posted April 20, 2023 Share Posted April 20, 2023 The measurement results of measuring points are locked in a specific alignment to display deviation and output dmo, which is similar to a function of PolyWorks, that is, the measuring points evaluated under these local systems are locked in this system and the results are output. Instead of locking alignment only in the three-dimensional view of the report page, it is particularly inconvenient to check whether these points are missing when outputting in the three-dimensional view. PolyWorks is a function directly, and the measuring point can be locked under which alignment. I hope GOMSoftware also has such a function command. Link to comment Share on other sites More sharing options...
[An...] Posted April 20, 2023 Share Posted April 20, 2023 (edited) if i understand good: you can measure same point in diferend alignments by copy it and change slignment by: f4> in point or normal choose arrow down and edit point or direction for reporting ...you can use this i-inspect menu for create new position but to make new one you must first unselect already reported point and select position and now you can select back your already reported point was it helpfull ? Edited April 20, 2023 Link to comment Share on other sites More sharing options...
[Na...] Posted April 20, 2023 Share Posted April 20, 2023 Hello 博文 戴, does this FAQ help you? How to visualize checks from different alignments in a table - GOM FAQ - GOM Connect Regards, Nanno Link to comment Share on other sites More sharing options...
[OL...] Posted June 20, 2023 Share Posted June 20, 2023 Please sign in to view this quote. hi Nanno, I don't know why I can not access the link. is there a possible that you pass the file direct to me? best regarts, oliver Link to comment Share on other sites More sharing options...
[Na...] Posted June 20, 2023 Share Posted June 20, 2023 Hi, the post links to the FAQ in GOM connect, which was deactivated with the ZEISS ID. The article is now in the techguide: https://techguide.gom.com/en/older-versions-faq/article/how_to_visualize_checks_from_different_alignments_in_table.html Nanno Link to comment Share on other sites More sharing options...
