[Kr...] Posted April 25, 2023 Share Posted April 25, 2023 Hello, I am using the inbuilt export function to output a CSV file of all the geometries I've created on a part. This is just using the standard "File > Export > Geometry > CSV" function. The problem is, I have input comments onto the features to highlight some important information about that features (for example what process it is in). Is there a way to adapt this CSV export so that it includes the comments for each point? It's crucial I get these comments out as I need the process to be contained within a single solution. Not adding them after. I did look into if I can adapt the CSV Export template (XSLZ) but I'm way out of depth when it comes to adapting that. Any help would be appreciated. Link to comment https://qualityforum.zeiss.com/topic/2881-csv-export-with-comments/ Share on other sites More sharing options...
[Na...] Posted May 4, 2023 Share Posted May 4, 2023 Hello Kristian, you are right, for this kind of export the XSLZ could be adapted, but I'm not sure how difficult this would be. The xml export will export the elements by default, maybe this is a solution? Nanno Link to comment https://qualityforum.zeiss.com/topic/2881-csv-export-with-comments/#findComment-7722 Share on other sites More sharing options...
