Hi GOM Team,
I'd like to edit a cell in the table, in order to calculate statistical parameters for a specific stage range.
For any project, after the reference image is obtained I capture 10 stages to evaluate measurement noise for each parameter. I then capture further stages to measure deformation etc.
In the table I would like to display the standard deviation for Stage 2 to Stage 11 only.
I have tried the function sigma(result_dimension.measured_value, index='stages'). However, this calculates the standard deviation for all the stages.
Is there a different expression that can be used instead of index='stages' to select a certain stage range?
Many thanks,
Jesse
https://qualityforum.zeiss.com/topic/289-standard-deviation-for-a-stage-range/
  • 3 weeks later...
Hi Ivan,
Thank you for your suggestion.
I've followed the steps in the link, but there is a problem at Workflow (Step 4). The expression does not accept the term "Range", and only accepts " 'stages' " (see screenshot 'Workflow_step4.png', compared to 'Workflow_step4_alt.png').
Do you know the reason for this?
Many thanks,
Jesse
