Change default location for user defined scripts
Can we change the default location for user defined python scripts inside of GOM?
Currently they rest here:
C:\Users\*USER*\AppData\Roaming\GOM\2021\gom_scripts
I'd like to be able to move them to a shared directory b/w many shared PC's:
Z:\GOMscripts
Thanks.
Hello Tim,
You can Export your scrips for any folder when needed you import them for use
If you use Visual Studio Code you can create and save were ever you want but you need to run your scrips on visual if not you have to import the script that you want to use to GOM system
