Templates and Updates
Hi all,
We currently have a GOM 6130 and a GOM 6235 (3 cells in total). We are supporting production by monitoring SPC data.
At first we were launching new product but have now moved into full production.
To achieve this we have created project templates for each part for each cell.
Our issue is template updates for run of the mill stuff eg. scale bar calibration.
Is there a quick way to update all of our templates quickly if, for example, our scale bars are calibrated and the certified length changes?
Or do we have to update each as and when it runs in the hope of not forgetting and getting incorrect results?
Nanno,
That is exactly what I wanted to hear.
Brilliant.
I will check the script out and see how I get on....
Nanno,
That worked perfectly.
The only slight issue was that the folder selector for the update would not work. Regardless of what was selected in the drop-down, it only appeared to select the root of the tree.
Thankfully in this case it was not required.
Thank you so much for your help. 👍❤️😊
