MMC for a line - need to get linear size
I'm trying to get the position of the mid point of a line constructed from 2 points. I also need MMC for the callout, but I cannot get a linear size from a line. Is there any workaround to do this instead of using user defined?
Thanks
That's too bad it cannot be done by way of creating a circle from the mid point and using an extreme end point of the line as the radius value. This would in essence create a circle feature. In this situation the created circle does not allow you to create a linear size. I think this should be a feature as I will need to use user defined to get this done in this situation.
