Image Size and Measuring Mode
Hi all,
I was wondering if there is a way to rotate the partial image HD image size. Currently, the rectangular FOV is wider in the horizontal direction, but I want it to be longer in the vertical direction. Does the ARAMIS Professional 2020 software have this capability?
Thanks!
  • 4 weeks later...
Hi Sara,
you can rotate the whole sensor. Go from  - to |
This will be at first quiet confusing but the software can work with.
Greetings Ivan
