Problem in Transformation
Hello!
How to transform front and rare side of scan by just putting points on table rather than object??
Is this Possible or not?
Hi,
for the transformation of measurement lists into a common coordinate system you need reference points which are moving with your scanned part (stuck with your part) to establish a common coordinate system. Or you use a reference point frame for purposes like this. The other possibility is to use your scanned shape via a Bestfit approach, but this is only possible if the common surface which is scanned in both measurement lists is unique enough to fix all six degrees of freedom of your transformation.
For further information contact your local GOM partner in your country.
Regards
