[Ha...] Posted June 16, 2023 Share Posted June 16, 2023 Hello ATOS users, I am reaching out to inquire if anyone has encountered and successfully resolved a "Dead Spot" or "Dark Shadow" problem in the ATOS II Triple Scan Projector lenses or mirror. Recently, my ATOS II Triple Scanner developed a minor shadow or dead spot, which has progressively worsened over the past four days, now significantly impacting data collection. The affected area is rendering the system incapable of capturing data or recognizing target points. Moreover, calibration attempts are futile due to the presence of this dead spot-See attached images or pictures. I kindly request assistance from anyone who possesses knowledge or experience in resolving this issue. Any insights or guidance would be immensely appreciated. Your assistance would greatly aid in restoring the functionality of our ATOS II Triple Scan Projector. Thank you very much for your attention and anticipated support. Sincerely, Hai Nguyen Link to comment https://qualityforum.zeiss.com/topic/3013-dead-spot-or-dark-shadow-in-the-atos-ii-triple-scan-projector-lenses-or-mirror/ Share on other sites More sharing options...
[Ja...] Posted June 16, 2023 Share Posted June 16, 2023 Hello Hai, the short answer is that you need a new LED unit. Contact your local distributor to sort this . Link to comment https://qualityforum.zeiss.com/topic/3013-dead-spot-or-dark-shadow-in-the-atos-ii-triple-scan-projector-lenses-or-mirror/#findComment-8003 Share on other sites More sharing options...
[Ch...] Posted July 13, 2023 Share Posted July 13, 2023 Please sign in to view this quote. Hello Hai Nguyen Could you give me your contact & Serial Number of system? We will contact to support you Thanks Link to comment https://qualityforum.zeiss.com/topic/3013-dead-spot-or-dark-shadow-in-the-atos-ii-triple-scan-projector-lenses-or-mirror/#findComment-8235 Share on other sites More sharing options...
[Ha...] Posted July 14, 2023 Author Share Posted July 14, 2023 Thank you Chuong, I sent the system to Capture3D for repair. They replaced the LED light source and it took care the issue. The system is back and it is running smoothly. Again, thanks for your hep and support. Have a blessed day. Link to comment https://qualityforum.zeiss.com/topic/3013-dead-spot-or-dark-shadow-in-the-atos-ii-triple-scan-projector-lenses-or-mirror/#findComment-8255 Share on other sites More sharing options...
[Ch...] Posted July 24, 2023 Share Posted July 24, 2023 Please sign in to view this quote. Dear Hai Nguyen Could you give me your information to support please? Thanks, Link to comment https://qualityforum.zeiss.com/topic/3013-dead-spot-or-dark-shadow-in-the-atos-ii-triple-scan-projector-lenses-or-mirror/#findComment-8303 Share on other sites More sharing options...
[Ha...] Posted August 1, 2023 Author Share Posted August 1, 2023 Hi Chuong, You can contact me at david@3dmetrologysolutions.com. By the way, are you a Zeiss, GOM, or Capture3D employee? Link to comment https://qualityforum.zeiss.com/topic/3013-dead-spot-or-dark-shadow-in-the-atos-ii-triple-scan-projector-lenses-or-mirror/#findComment-8422 Share on other sites More sharing options...
