[Ca...] Posted June 16, 2023 Share Posted June 16, 2023 Hi. I'm currently using GOM to have the strain components of a curve surface. I can have the values of epsilon (X), epsilon (Y) and epsilon (XY) by going to the Inspect>Check dimensions>Strains but I can't find a way to get epsilon (Z), epsilon (Z), epsilon (YZ) or epsilon (XZ). Is there another solution that will allow me to get these strain components? Thank you, in advance for your valuable assistance. Have a good day Cam Link to comment Share on other sites More sharing options...
[Iv...] Posted July 14, 2023 Share Posted July 14, 2023 Hello Camille , no that's not possible. We are working on the 2D surface. Please check the direct help for more information. Link to comment Share on other sites More sharing options...
[Vi...] Posted July 17, 2023 Share Posted July 17, 2023 Hi Camille, I am also interested in obtaining a out-of-plane strain in a 3D measurement. @Ivan, if it is a 3D measurement, is there any way to get a out-of-plane strain such as epsilon (z) or epsilon (yz)? Link to comment Share on other sites More sharing options...
[Th...] Posted September 21, 2023 Share Posted September 21, 2023 Hi, you can use: Inspection - Check Dimensions - Strains - Check Thickness Strain. But be aware that this is only a calculated value using volume constancy. Eps (yz) is not calculated out of the box. Link to comment Share on other sites More sharing options...
[Fi...] Posted February 29 Share Posted February 29 Hello, I am looking for a program that can calculate deformation from a video. Link to comment Share on other sites More sharing options...
