Acquisition parameters: Allowed temp.diff. change
Hello,
We would like to change Allowed temperature difference in Acquisition parameters permanently.
How can I do it? For us it turns back to the default 5.00 °C at every program start.
Best regards,
Máté
Hello,
a possible solution is to work with a project template: create a new project, set the temperature difference and possibly other settings to the values you like and choose File - Create Template from Project... To use it: Don't click "New Project" but "Project Templates" in the Start screen.
Side note: If you are not interested in temperature checks at all, you can turn off the temperature query permanently in Edit - Preferences - Hardware - Thermometer (change to "Ask for temperature only if required"). Mind that temperature is still queried for technical reasons for calibration or if using reference point frames.
Regards
Matthias Aalto
