How to get a 14 day trial version?
Is it possible for you to login to Zeiss Quality Suite (upright corner)?  Then you need to confirm some services as the store to get access to this.
Then try to open the store - if the profile data appears click with rmb into your window and set the page to "home" if everything is fine you will be redirected correctly.
  • 2 weeks later...
  • 5 weeks later...
Hi, Christine!
When we click on GOM Inspect we see the following window, see below.
Also, when you try to log in in the right corner, we see the download animation, but nothing happens after it, the login or activation of the trial version is not performed.
2023-8-1 14-43
It seems to me that your registration is incomplete.
Did you login here:
You need access to some urls
You can find these here:
https://techguide.gom.com/en/gom-software-2022/article/faq_zeiss_quality_suite.html
Is it possible to access Training or the Tech Guide?
