How to get a 14 day trial version?
Hi,
We want to test the GOM inspector, but when you click the Login button, nothing happens.
The download icon appears, after which it redirects to the profile page, that's all.
Does getting a trial is work?
Regards,
Alex
Is it possible for you to login to Zeiss Quality Suite (upright corner)?  Then you need to confirm some services as the store to get access to this.
Then try to open the store - if the profile data appears click with rmb into your window and set the page to "home" if everything is fine you will be redirected correctly.
Hi, I'm having the exact same problem.
I've tried to login from the upright corner, showing the profile page. However when I click in the software there is no 'trial' button.
Could anyone help? Thanks
  • 2 weeks later...
  • 5 weeks later...
Hi, Christine!
When we click on GOM Inspect we see the following window, see below.
Also, when you try to log in in the right corner, we see the download animation, but nothing happens after it, the login or activation of the trial version is not performed.
2023-8-1 14-43
