Single camera surface analysis in Correlate Pro?
Hello everyone,
I'm currently working with the ARAMIS 3D 12M system and have a quick question. Due to spatial limitations in my setup, I'm forced to use only one camera and the deformation I'm observing stays mostly within the plane.
Is it possible to perform 2D surface analysis in Correlate Pro using a single camera? Any advice or guidance would be greatly appreciated.
Thank you,
Philipp Charvalakis
Hello,
yes it is possible. Just unplug the one camera on the computer side and do a sensor analysis.
Afterwards you can measure with only one camera. But be aware of the limits you can face with a 2D measurement and the necessary setup you should provide.
Greetings Ivan
