[Mi...] Posted July 3, 2023 Share Posted July 3, 2023 Hello, I have a part that has several of the same embossing. The alignment for each embossing is built the same. Is it possible to do the alignment + evaluation only once and then copy and apply it to the rest of the embossings? Would it be possible to solve this via a script? Thought process: 1. create the "coarse coordinate system" for embossing 1. 2. use coordinates for "fine alignment" from the "coarse coordinate system". 3. perform evaluation in the "fine coordinate system". Create script with steps 2. and 3. 4. create all other "coarse coordinate systems". 5. run script on the remaining "coarse coordinate systems". I hope you can understand me. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 18, 2023 Share Posted December 18, 2023 Hi, Maybe you can achieve this with the cluster concept (see How to Evaluate Clusters). Best regards, Matthias Prinke Link to comment Share on other sites More sharing options...
