[Ch...] Posted July 17, 2023 Share Posted July 17, 2023 Hi, I would like to be able to control my gom ROT640 rotation table via scripting. My goal is to be able to move the table a specified angle without having to run the 'measure with rotation table' feature. Is there a way to do this? Thanks! Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/ Share on other sites More sharing options...
[Ja...] Posted July 22, 2023 Share Posted July 22, 2023 Christian, im afraid this isnt possible, it does not have encoders like a robot. What is your goal here? Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/#findComment-8299 Share on other sites More sharing options...
[e7...] Posted July 24, 2023 Share Posted July 24, 2023 This script will move the rotation table either by one specified angle of rotation or through an interval by adding new "intermediate positions" based on wherever the current robot position is. You might need to add some checks for if the rotation table is already at its max rotation, to reverse the degree of rotation (or however is necessary) # -*- coding: utf-8 -*- import gom dialog=gom.script.sys.create_user_defined_dialog (content='<dialog>' \ ' <title>Move Rotation Table</title>' \ ' <style></style>' \ ' <control id="OkCancel"/>' \ ' <position></position>' \ ' <embedding></embedding>' \ ' <sizemode></sizemode>' \ ' <size height="288" width="198"/>' \ ' <content columns="2" rows="7">' \ ' <widget rowspan="1" row="0" type="input::checkbox" column="0" columnspan="2">' \ ' <name>check_single</name>' \ ' <tooltip></tooltip>' \ ' <value>true</value>' \ ' <title>Single Rotation:</title>' \ ' </widget>' \ ' <widget rowspan="1" row="1" type="separator" column="0" columnspan="2">' \ ' <name>separator</name>' \ ' <tooltip></tooltip>' \ ' <title></title>' \ ' </widget>' \ ' <widget rowspan="1" row="2" type="input::integer" column="0" columnspan="2">' \ ' <name>single</name>' \ ' <tooltip></tooltip>' \ ' <value>90</value>' \ ' <minimum>15</minimum>' \ ' <maximum>360</maximum>' \ ' </widget>' \ ' <widget rowspan="1" row="3" type="input::checkbox" column="0" columnspan="2">' \ ' <name>check_multi</name>' \ ' <tooltip></tooltip>' \ ' <value>false</value>' \ ' <title>Multiple Rotation:</title>' \ ' </widget>' \ ' <widget rowspan="1" row="4" type="separator" column="0" columnspan="2">' \ ' <name>separator_1</name>' \ ' <tooltip></tooltip>' \ ' <title></title>' \ ' </widget>' \ ' <widget rowspan="1" row="5" type="label" column="0" columnspan="1">' \ ' <name>label</name>' \ ' <tooltip></tooltip>' \ ' <text>Total Rotation:</text>' \ ' <word_wrap>false</word_wrap>' \ ' </widget>' \ ' <widget rowspan="1" row="5" type="input::integer" column="1" columnspan="1">' \ ' <name>total_rotation</name>' \ ' <tooltip></tooltip>' \ ' <value>360</value>' \ ' <minimum>90</minimum>' \ ' <maximum>360</maximum>' \ ' </widget>' \ ' <widget rowspan="1" row="6" type="label" column="0" columnspan="1">' \ ' <name>label_1</name>' \ ' <tooltip></tooltip>' \ ' <text>Interval:</text>' \ ' <word_wrap>false</word_wrap>' \ ' </widget>' \ ' <widget rowspan="1" row="6" type="input::integer" column="1" columnspan="1">' \ ' <name>interval</name>' \ ' <tooltip></tooltip>' \ ' <value>6</value>' \ ' <minimum>2</minimum>' \ ' <maximum>24</maximum>' \ ' </widget>' \ ' </content>' \ '</dialog>') def dialog_event_handler (widget): if widget=='initialize': dialog.total_rotation.enabled=False dialog.interval.enabled=False if widget==dialog.check_multi and dialog.check_multi.value==True: dialog.check_single.value=False dialog.single.enabled=False dialog.total_rotation.enabled=True dialog.interval.enabled=True if widget==dialog.check_multi and dialog.check_multi.value==False: dialog.check_single.value=True dialog.single.enabled=True dialog.total_rotation.enabled=False dialog.interval.enabled=False if widget==dialog.check_single and dialog.check_single.value==True: dialog.check_multi.value=False dialog.single.enabled=True dialog.total_rotation.enabled=False dialog.interval.enabled=False if widget==dialog.check_single and dialog.check_single.value==False: dialog.check_multi.value=True dialog.single.enabled=False dialog.total_rotation.enabled=True dialog.interval.enabled=True dialog.handler = dialog_event_handler scanbox=None for setup in gom.app.project.measuring_setups: if setup.is_active: scanbox=setup.working_area.controller.name if scanbox==None: print('no scanbox') quit() robot=None table=None for component in gom.app.project.virtual_measuring_room[scanbox].components: if component.type=='robot': robot=component.name if component.type=='rotation_table': table=component.name if robot==None: print('no robot') quit() if table==None: print('no roto table') quit() current_position = [gom.app.project.virtual_measuring_room[scanbox].components[robot].get ('axis_info[0].current_position'), gom.app.project.virtual_measuring_room[scanbox].components[robot].get ('axis_info[1].current_position'), gom.app.project.virtual_measuring_room[scanbox].components[robot].get ('axis_info[2].current_position'), gom.app.project.virtual_measuring_room[scanbox].components[robot].get ('axis_info[3].current_position'), gom.app.project.virtual_measuring_room[scanbox].components[robot].get ('axis_info[4].current_position'), gom.app.project.virtual_measuring_room[scanbox].components[robot].get ('axis_info[5].current_position'), gom.app.project.virtual_measuring_room[scanbox].components[table].get ('axis_info[0].current_position')] roto=current_position[-1] result=gom.script.sys.show_user_defined_dialog (dialog=dialog) if result.check_single==True: rotation=int(result.single) position=gom.script.automation.insert_intermediate_position (position={ scanbox : current_position }) gom.interactive.automation.move_to_position(measurement=position) current_position[-1]=rotation+roto position=gom.script.automation.insert_intermediate_position (position={ scanbox : current_position }) gom.interactive.automation.move_to_position(measurement=position) else: total_rot=int(result.total_rotation) interval=int(total_rot/int(result.interval)) for i in range(0,total_rot,interval): current_position[-1]=i+roto position=gom.script.automation.insert_intermediate_position (position={ scanbox : current_position }) gom.interactive.automation.move_to_position(measurement=position) Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/#findComment-8317 Share on other sites More sharing options...
[Ch...] Posted July 26, 2023 Author Share Posted July 26, 2023 Hi James, My ultimate goal is to be able to use angles from live tracking to input into a script that will then move the rotation table the specified angle. Hi Robert, Do you need a special license for the 'gom.interactive.automation.move_to_position' command? When running this I get an error that I do not have the correct license to run that command. Thanks! Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/#findComment-8342 Share on other sites More sharing options...
[Ja...] Posted July 26, 2023 Share Posted July 26, 2023 Christian, robert has provided code relevant to a scanbox /vmr setup. this does not apply in your case , as i said the rot 640 does not have encoders so sadly you cannot pass it angles to turn to. What are you live tracking? Why is this angle rotation useful? Im trying to understand your application , it isnt possible to do what you want with the rotation table but maybe there is a different method/approach to get a solution. Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/#findComment-8344 Share on other sites More sharing options...
[Mi...] Posted July 27, 2023 Share Posted July 27, 2023 you could try this to move your table in position: gom.script.automation.measure_with_rotation_table ( invert_rotation_direction=False, move_to_first_position_only=True, number_of_rotation_steps=1, number_of_tilt_steps=1, return_to_start_position=False, start_angle=20, tilt_end_angle=0, tilt_start_angle=0, total_coverage=0) start_angle (20) could be your input from a dialog Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/#findComment-8368 Share on other sites More sharing options...
[Di...] Posted August 2, 2023 Share Posted August 2, 2023 Hello I use a simple code to do the rotation I don't no if it helps import gom gom.script.automation.measure_with_rotation_table ( invert_rotation_direction=False, number_of_rotation_steps=0, return_to_start_position=False, start_angle=0, total_coverage=0, move_to_reference_position=True) # Move to start position gom.script.automation.measure_with_rotation_table ( invert_rotation_direction=False, number_of_rotation_steps=8, return_to_start_position=False, start_angle=70, total_coverage=360) # colect photos on a certain angle Link to comment https://qualityforum.zeiss.com/topic/3085-controlling-the-gom-rotation-table-via-scripting/#findComment-8430 Share on other sites More sharing options...
