[Jo...] Posted July 26, 2023 Share Posted July 26, 2023 I have an Aramis SRX system and I'm running with a GOM provided laptop and Thunderbolt Adapter, when I initiate the sensor and the camera is active I got to either the Data Aquisition tab or the setup tab to adjust the exposure. When I manually click and drag to adjust the exposure the system begins to crash and then this error will display, the cameras will then become deinitialized and will not be able to connect. I've tried switching the ports where the cable between the Thunderbolt Adapter and laptop connect and it seems this issue continues to happen. I have also tried powering the whole system off and unplugging and replugging all the cables back in with the same issue. IP addresses within the cameras and controllers are correct as well and have not changed during this issue. Thanks for any advice. Link to comment Share on other sites More sharing options...
[Na...] Posted July 27, 2023 Share Posted July 27, 2023 Hello Josh, please contact your local support with this issue since it is to complex for this forum. Regards Nanno Link to comment Share on other sites More sharing options...
