[Ti...] Posted July 30, 2023 Share Posted July 30, 2023 I need to create a cone from these two circles. Both circles are parallel to each other as they were created from the same axis. Is there a way to create a cone from these two circles? Thanks. Link to comment Share on other sites More sharing options...
[Be...] Posted July 31, 2023 Share Posted July 31, 2023 The "easiest" way would be: Create curves from your both circles Select all points of these two curves Create a fitting cone Hope this helps?! Regards, Bernd Link to comment Share on other sites More sharing options...
[Ti...] Posted August 8, 2023 Author Share Posted August 8, 2023 Please sign in to view this username. I was able to create the curves from the circles, but it said it couldn't create a fitting cone from the two curves. I may open a ticket and send to our local support at Zeiss. Link to comment Share on other sites More sharing options...
[Be...] Posted August 9, 2023 Share Posted August 9, 2023 Sorry to hear that, but as always, for concrete data problems you should always contact the Professional Support with your concrete data, the Forum is not the right place for discussing problems like that. I tried my recommended steps and they worked as expected. Regards, Bernd Link to comment Share on other sites More sharing options...
