Errors while computing Virtual clamping
Product: GOM Inspect Pro, version 4.4.1361.0
Issue: Encountering errors during virtual clamping computation:
  1. Error message indicates voxel size is too large compared to the bounding box to create a meaningful volume in the x direction. Recommended voxel size is below 0.5mm. Using a 64GB RAM device.
  2. Error message indicates only 25% of element is captured by measurements from the viewing direction with tilt angle around +/-10 & 40 degree.
  3. Error message indicates deformation of the mesh failed due to insufficient memory (RAM).
Part Details: Flat plate CAD part measuring 750*800 mm and 1 mm thickness with 8 clamping points. Four points are surface supported from bottom and four are edge supporters.
Troubleshooting: I tried to adjusted the voxel size to above 0.5mm it is not computing the deformation model and if it is below 0.5mm it says out of memoty. No further troubleshooting steps were taken.
Thank you so much for your response, Nanno
I will contact the support.
Regards,
Keloth
