[ba...] Posted August 1, 2023 Share Posted August 1, 2023 Product: GOM Inspect Pro, version 4.4.1361.0 Issue: Encountering errors during virtual clamping computation: Error message indicates voxel size is too large compared to the bounding box to create a meaningful volume in the x direction. Recommended voxel size is below 0.5mm. Using a 64GB RAM device. Error message indicates only 25% of element is captured by measurements from the viewing direction with tilt angle around +/-10 & 40 degree. Error message indicates deformation of the mesh failed due to insufficient memory (RAM). Part Details: Flat plate CAD part measuring 750*800 mm and 1 mm thickness with 8 clamping points. Four points are surface supported from bottom and four are edge supporters. Troubleshooting: I tried to adjusted the voxel size to above 0.5mm it is not computing the deformation model and if it is below 0.5mm it says out of memoty. No further troubleshooting steps were taken. Link to comment Share on other sites More sharing options...
[Na...] Posted August 2, 2023 Share Posted August 2, 2023 Hello, this is probably out of scope for a forum, so contact the support with the concrete data please. Regards, Nanno Link to comment Share on other sites More sharing options...
[ba...] Posted August 2, 2023 Author Share Posted August 2, 2023 Please sign in to view this quote. Thank you so much for your response, Nanno I will contact the support. Regards, Keloth Link to comment Share on other sites More sharing options...
