[Fe...] Posted August 11, 2023 Share Posted August 11, 2023 I have a test that is going to run the course of a few weeks. We don't need the camera to run that entire length of time. What we would like to do is take a sequence of images every hour, save that sequence of images onto a hard drive, and then once the test has been completed compile the sequences into one project. From my understanding I would need to use the export all active stages as image series function. But I've noticed that every time I try to do this it overrides the previous stage that I saved. Is there an easier way to save multiple stages with a unique name? I'm aware that in order to automate the process I would need to use the python script, but I figured that I should first find out if this is even achievable in the first place. Link to comment Share on other sites More sharing options...
[Na...] Posted August 21, 2023 Share Posted August 21, 2023 Hello, in general a custom export with a name is possible. The name could be a static part like the project name and a dynamic part like the stage index for example, but I don't know your exact application. (Moving this question to the customization forum) Nanno Link to comment Share on other sites More sharing options...
[Th...] Posted September 21, 2023 Share Posted September 21, 2023 If you want to take a number of images each hour you can do something like: A scripted solution would be better as you save working copies/ project in between. Something like: while true: do measurement save project wait X seconds Link to comment Share on other sites More sharing options...
