Documentation for the gom libary
Hello everyone,
is there any documentation for the gom library in Python? I would like to know about the different functions that are implemented in the library, as well as the needed input and output parameters.
Thanks in advance.
  • 3 weeks later...
There is no such documentation as the gom library just maps all internal command calls and parameters onto python commands. So the usual way to get a function is to record the usage of the according command. If you need some further advice about special commands or object types you can try to use the python __doc__-access.
import gom
print (gom.Vec3d (0.0, 0.0, 0.0).__doc__)
  • 2 years later...
