Changing Reference Frame in a Template?
Hi,
Im using GOM Correlate to analyse High Speed 2D images taken from an external source (Photron High Speed camera). Due to changes in the velocity of the dynamic tensile test (using a pendulum impactor and a fixed 9000 FPS framerate for all tests) - the reference stage will change when the test impact velocity changes.
I have setup all the measurements I need and saved as a Template, but need to change the Reference Stage depending on the test velocity. Is there a way to update which stage is used as a reference stage once the Template is loaded (for about 15 measurements) ? Or Is there a better way to do this (ie record a macro where the user defines the Reference stage before the measurements are created?)
Thanks.
  • 4 weeks later...
Hi Mark,
I would go for manual editing of the reference stage after the import each of the measurements into the Template.
If you have a strict relation of reference time (and thus stage index) and impact speed, you can also record a script to set the Reference Stage automatically (as you mentioned/ intended?!). You can even script a function to get the index of needed stage from stage time, if needed.
Hope this helps,
Best regards,
Thorsten
