[Ti...] Posted September 6, 2023 Share Posted September 6, 2023 I created a section that is a 180 deg arc. I created a circle and measured the radius. I need to get an end point of this arc for another dimension. I spent 2 hrs trying to do this. Is there a way to do this? Thanks. Link to comment https://qualityforum.zeiss.com/topic/3220-can-you-get-the-end-point-of-a-arc-section/ Share on other sites More sharing options...
[Na...] Posted September 7, 2023 Share Posted September 7, 2023 Hello Tim, you can create a point from line from a section or curve. Or you could create some kind of touch point, which is projected on the curve instead of the mesh. Nanno Link to comment https://qualityforum.zeiss.com/topic/3220-can-you-get-the-end-point-of-a-arc-section/#findComment-8726 Share on other sites More sharing options...
[Be...] Posted September 7, 2023 Share Posted September 7, 2023 Hi Tim, one further remark: If you need the results on the fitted circle you have to project the result of the touch point/end point onto the fitting circle and your projection mode is 'Curve'. Hope this helps?! Regards, Bernd Link to comment https://qualityforum.zeiss.com/topic/3220-can-you-get-the-end-point-of-a-arc-section/#findComment-8728 Share on other sites More sharing options...
[Ti...] Posted September 8, 2023 Author Share Posted September 8, 2023 Thanks guys. The tolerance is large on this feature so I just made a line. I may project something onto the end point later on for more accuracy Link to comment https://qualityforum.zeiss.com/topic/3220-can-you-get-the-end-point-of-a-arc-section/#findComment-8748 Share on other sites More sharing options...
