iDICs "Image Scale" parameter - where to find it?
Greetings,
I use ARAMIS 2020, and I am trying to find the "Image Scale" parameter as defined in the iDIC Good Practices Guide. The units of the quantity are in pixels/mm, and it depends on camera resolution, lenses, Field of view and stand off distance. I would like to find what the image scale is in both cameras in a stereo DIC setup, or in one camera if only operating in 2D.
Note that this value is referenced in the ARAMIS App as "Local Resolution."
Thank you,
Austin
  • 2 years later...
Hey Austin,
The iDIC "Image Scale" value is the same as "Local Resolution" in the ARAMIS App.
To find it:
ARAMIS App → Select your camera, lens, and measuring volume → Read the "Local Resolution" value (px/mm).
That Local Resolution value is the image scale used in the iDIC Good Practices Guide.
