[Ko...] Posted September 26, 2023 Share Posted September 26, 2023 Hello, GOM community! I'm a new user and wanted to find out if it is possible to do the following Import a CAD body, which will be the basis for the comparison Import a mesh of the 3D printed part to compare against the CAD body Import a 2nd mesh of another 3D printed part to also compare against the CAD body Import a 3rd mesh of another part to compare When I import the additional meshes, I'm finding that I cannot perform an accurate local best fit on each imported mesh; the software seems to only allow for a local best fit on one mesh at a time. My ultimate goal is to simultaneously compare the accuracy of the outputs from different 3D printers against the original CAD in one GOM project. Is this possible? Thank you in advance for your thoughts and consideration! Kojo Link to comment Share on other sites More sharing options...
[Be...] Posted September 27, 2023 Share Posted September 27, 2023 I answered your question already! Link to comment Share on other sites More sharing options...
[Ko...] Posted September 28, 2023 Author Share Posted September 28, 2023 👍🏿 Link to comment Share on other sites More sharing options...
[ph...] Posted February 13, 2024 Share Posted February 13, 2024 Please sign in to view this quote. Hi , apologies for jumping on this thread but is it possible to detail the location of the steps in this function please? i am looking into doing exactly the same on mulitple same parts. thanks Link to comment Share on other sites More sharing options...
[ph...] Posted February 13, 2024 Share Posted February 13, 2024 Hi , apologies for jumping on this thread but is it possible to detail the location of the steps in this function please? i am looking into doing exactly the same on mulitple same parts. Link to comment Share on other sites More sharing options...
[Be...] Posted February 13, 2024 Share Posted February 13, 2024 My answer from the copied post: Hi, this is possible with the professional version of our software. You can create a trend project and compare each mesh against the CAD and you can even create a small statistic if you choose 'Deviation on CAD'. You can also visualize the differences between the actual meshes against each other. Regards, Bernd Link to comment Share on other sites More sharing options...
