Simultaneously comparing multiple 3D printed outputs against the original CAD
Hello, GOM community! I'm a new user and wanted to find out if it is possible to do the following
  1. Import a CAD body, which will be the basis for the comparison
  2. Import a mesh of the 3D printed part to compare against the CAD body
  3. Import a 2nd mesh of another 3D printed part to also compare against the CAD body
  4. Import a 3rd mesh of another part to compare
When I import the additional meshes, I'm finding that I cannot perform an accurate local best fit on each imported mesh; the software seems to only allow for a local best fit on one mesh at a time.
My ultimate goal is to simultaneously compare the accuracy of the outputs from different 3D printers against the original CAD in one GOM project. Is this possible?
Thank you in advance for your thoughts and consideration!
Kojo
  • 4 months later...
Hi , apologies for jumping on this thread but is it possible to detail the location of the steps in this function please? i am looking into doing exactly the same on mulitple same parts.
thanks
My answer from the copied post:
Hi,
this is possible with the professional version of our software. You can create a trend project and compare each mesh against the CAD and you can even create a small statistic if you choose 'Deviation on CAD'. You can also visualize the differences between the actual meshes against each other.
Regards,
Bernd
