[Br...] Posted July 28, 2021 Share Posted July 28, 2021 Hello, Is there a way to get X and Y dimension of a boss that is not in the main datum system of my part. I have a part that has 4 bosses around the part. They are on an angle so i have created a coordinate system based off each boss face to get the true position. I want to know how much each boss is out of position based on the X and Y coordinates. Link to comment https://qualityforum.zeiss.com/topic/328-xy-dimension-in-datum-system/ Share on other sites More sharing options...
[Br...] Posted July 28, 2021 Author Share Posted July 28, 2021 I found out that you can right click on your True position label and select "Results-Directions" under the "Choose Visualization" menu. Link to comment https://qualityforum.zeiss.com/topic/328-xy-dimension-in-datum-system/#findComment-942 Share on other sites More sharing options...
