[Je...] Posted October 18, 2023 Share Posted October 18, 2023 Hi, I have registered for the trial version of GOM correlate pro within the ZEISS quality suite but still I only see the viewer options. You can see from the image below that I am running the 4.5.1371.0 version. How can i fix it? Thanks Link to comment https://qualityforum.zeiss.com/topic/3335-zeiss-quality-suite-only-viewers/ Share on other sites More sharing options...
[Ax...] Posted October 19, 2023 Share Posted October 19, 2023 Are you logged in with the Zeiss ID? Link to comment https://qualityforum.zeiss.com/topic/3335-zeiss-quality-suite-only-viewers/#findComment-9173 Share on other sites More sharing options...
[Je...] Posted October 20, 2023 Author Share Posted October 20, 2023 Thanks Axel, I am logged in with the ZEISS ID. I have also tried to install the Zeiss Quality Suite on other machines (and log in) but I still see only the "viewer" option. Thanks Link to comment https://qualityforum.zeiss.com/topic/3335-zeiss-quality-suite-only-viewers/#findComment-9196 Share on other sites More sharing options...
