[Má...] Posted August 3, 2021 Share Posted August 3, 2021 Hello All, On the attached picture you can see a curve curvature change with colors. I checked the max./min. points of it. It has a value "/mm". What is it actually mean in this situation? We would like to check normal direction change (angle change) at given distance so it could help I guess. Best regards, Máté Link to comment Share on other sites More sharing options...
[Jo...] Posted August 3, 2021 Share Posted August 3, 2021 Hello, I would assume that "/mm" actually means "1/mm", which should correspond to the unit of curvature. Best regards, Jonas Link to comment Share on other sites More sharing options...
[Má...] Posted August 3, 2021 Author Share Posted August 3, 2021 Hello, Curvature must be calculated somehow. In this case a formula would help if it is available. BR, Máté Link to comment Share on other sites More sharing options...
