How to create a wall thickness analysis on a cylinder without the cad.
Hello. I am trying to create a wall thickness analysis of a cylinder. How can I set the minumum and maximum deviation distance values of the inside diameter to the outside diameter. I wanted to make like a heat map that indicates the deviation along the cylinder.
Hello Jose,
the expected minimum and maximum material thickness is set in the dialog for the material thickness. If you only want to display values from the inside to the outside, you have to select only the inner surface during the creation.
ZEISS Quality Tech Guide
Nanno
