[35...] Posted November 13, 2023 Share Posted November 13, 2023 Im experiencing fairly regular software crashes when using the command Construct -> Point -> Equidistant Points -> Vector Points on Section/Edge I have the command "gom.script.primitive.create_equidistant_vector_points_on_section" as part of a script to deselect points on a section based on the points created by this command, however it has been causing a "application hang" crash under certain conditions Because this is being ran from a script, I have a part of the section already selected before I run the command. I can also recreate the crash if I select an area on the section while the "interactive" command window is open. I am using GOM 2020 Hotfix 5 Link to comment https://qualityforum.zeiss.com/topic/3411-frequent-software-crashes-on-command-construct-point-equidistant-points-vector-points-on-sectionedge/ Share on other sites More sharing options...
[Be...] Posted November 14, 2023 Share Posted November 14, 2023 Hi, I repeat myself: For concrete "crashes" with concrete data constellations please contact your local ZEISS support. Supply the data and your script/workflow for reproducing the "bug". Then we can try to investigate why your application stalls for so long (infinite loop, etc. ). Thanks in advance! Regards, Bernd Link to comment https://qualityforum.zeiss.com/topic/3411-frequent-software-crashes-on-command-construct-point-equidistant-points-vector-points-on-sectionedge/#findComment-9483 Share on other sites More sharing options...
[35...] Posted November 20, 2023 Share Posted November 20, 2023 Ok sorry about that, Hans Link to comment https://qualityforum.zeiss.com/topic/3411-frequent-software-crashes-on-command-construct-point-equidistant-points-vector-points-on-sectionedge/#findComment-9569 Share on other sites More sharing options...
