[Mi...] Posted November 15, 2023 Share Posted November 15, 2023 Anyone know how to take a manual actual point with stages? I need to locate several features across stages that aren't in the same location from part to part. Link to comment Share on other sites More sharing options...
[Ja...] Posted November 15, 2023 Share Posted November 15, 2023 Is this in a stage project with meshes? Whatever the case this is hard to realize with parametrics...when you say not in the same location , by how far? If they are totally different does a stage project make senze? If you have a chance to add some images for context it would help a lot with understanding what may be possible. Link to comment Share on other sites More sharing options...
[Se...] Posted November 16, 2023 Share Posted November 16, 2023 Hi, We faced this problem in the past for example on the surface defect inspection, because the defects are at different position on each stage. The problem was solved in that case with a so called scripted element: an actual point is created for example on the worst defect on each stage, based on another element (surface defect map classification) in a parametric way > See scripted_actuals — Add-On Documentation documentation (zeissiqs.github.io) for more information about scripted elements > The add on "Create Surface Defect Checks" has an implementation of the example above Hope this helps Link to comment Share on other sites More sharing options...
