Separating Mesh after Cutting Along Curve
Hi,
After using the 'Cut Actual Mesh by Curve' tool, is there a way to easily separate the mesh into separate entities along that curve?
Thanks
Hi,
if the mesh is cutted in a topological way - means triangles are not connected to each other anymore - you can use 'Select patch' to select the vertices (triangles) you are interested in. Afterwards you can call 'Copy selected points' or you can create 'Surface element' based on this point selection. Keep in mind: In the part workflow you can have only one unique Mesh-object. Separation is done via PatchCompound-Objects on CAD or surface elements on actual.
Hope this helps?!
Regards,
Bernd
