[Mi...] Posted December 13, 2023 Share Posted December 13, 2023 Hello everyone, I'm looking for a solution to add a sound to the end of a measurement in Kiosk mode to notify the operators of the end of the measurement before pressing the APPROVE button on the screen. We have a large measurement room with other machines and there is no direct view of the screen and it is hard to tell if the measurement is finished, so some sound at the end would help. Is this a possibility? Thanks. Link to comment Share on other sites More sharing options...
[Mi...] Posted December 13, 2023 Share Posted December 13, 2023 Miro, I've added sounds to a couple Python scripts outside of GOM, and I think the methods I used would still work within GOM's interpeter... Method 1: Playsound module from playsound import playsound playsound('C:/Users/User/Music/sound.mp3') #Enter the filepath to your MP3 or WAV file as the argument This is the easiest method I found, however keep in mind that the script will basically pause itself until the sound finishes playing, so if you have a long soundfile or place it somewhere other than the very end of the script, this may create a timing delay until the script finishes. Method 2: Base64 Embedding into script import base64, winsound Encoded_TaDa_WAV = b'UklG.......' #Truncated for clarity, this is a base64-encoded byte string of a WAV soundfile that I've embedded in my script so that I don't have to relay on an outside file dependency sound_file_data = base64.b64decode(Encoded_TaDa_WAV) #Decodes the base64 soundfile string at runtime winsound.PlaySound(sound_file_data, winsound.SND_MEMORY) #Plays the decoded sound and immediately continues the script without waiting for the sound to finish I switched to Method 2 in my program because I like the appeal of having the sound "built-in" to the script without requiring an outside file dependency, and because the Winsound module will play the sound and continue the script simultaneously. There are some online encoders that can convert files to base64, or you can do it within Python itself using the same base64 module. If you prefer to use Winsound without encoding the sound file I think it supports taking a WAV filepath as a different argument, it's just not how I chose to implement it. Hope this helps! Regards, Michael Henson Link to comment Share on other sites More sharing options...
