2023 Free License - Zeiss Inspect or Inspect correlate .
Are you able to create a new project after the trial in 2023?
They are working out a dongle issue for us for one of our 4 dongles and I cannot create a project in 2023 on that computer.
I thought in 2021 you could create a project, but you could not edit a feature and you could not do scripting? Did this change in 2023 where you can't start a limited project like you could in 2021?
Thanks.
  • 1 year later...
I'm trying to download the free versionnof the zeiss inspect but it just says incorrect request something went wrong. What else can I do?
Hi Lalitesh,
The trial for 2023 has passed; hopefully, you were able to download it before the deadline.
Eleva Andujo,
For the 2025 software, you can access the  ZEISS Portal  Please note that you will need a Zeiss account to proceed. If you don't already have one, you can register for an account.
Once registered, please confirm and verify your email. If you already have an account, simply sign in and navigate to the download center. From there, you can download the ZQS or the Inspect installer. Please ensure that you have version ZQS 6.1 or newer for 2025.
If you already have the ZQS installed, go to the gear icon in the top right corner and update the ZQS to the latest version. Then, head to the available applications, and you should see the Inspect software for 2025. Install the software and select the trial option you prefer. If the trial and free options are grayed out, please confirm that you are logged into your account.
Best regards,
I already downloaded and installed ZQS and Inspect. I still don't have a license. When I try to access a free license from ZQS, an 'incorrect request' message appears.
  • 3 weeks later...
  I would reach out to your local ZEISS Support team as this may require additional troubleshooting.
