[Mo...] Posted January 6, 2024 Share Posted January 6, 2024 hi, Im a last year student in finland and i wish to use GOM inspect 2022 for a limited period (2 Month), is there a possibility to have such a subscription for students? I need possibility to import file and perform some operations under construct menu (adding planes and etc) its a part of my final thesis under the title of (Application of Reverse engineering in rubber industries). Thanks Link to comment Share on other sites More sharing options...
[24...] Posted January 8, 2024 Share Posted January 8, 2024 Is there a reason you cant use an older version? For example V8? IIRC you can do basic functions like you describe in V8 without a license Link to comment Share on other sites More sharing options...
[Mo...] Posted January 10, 2024 Author Share Posted January 10, 2024 Hi, Thanks for return, could you explain how can i access to V8? Currently i have access to GOM2019 how can i get V8? waht does IIRC stands for? Thanks Link to comment Share on other sites More sharing options...
[Na...] Posted January 10, 2024 Share Posted January 10, 2024 Hello, constructions and import of basic file formats is also supported by the free version, which the test version will switch two after two weeks. In the two weeks you have the full version with parametric etc. The current version can be downloaded via the blue bar on top of the page for example. Nanno Link to comment Share on other sites More sharing options...
[St...] Posted January 11, 2024 Share Posted January 11, 2024 Hi You can contact www.cascade.fi , Cascade Control Finland // Stefan Link to comment Share on other sites More sharing options...
