I just scanned a stamping die today, which is a bit new for me. Can anyone give me advice on filtering the scan? I figure there may be a little noise or even some areas where I may have sprayed too much and created a small drip effect that needs to be filtered.
I dont want to go overboard. Can anyone give me a little guidance on how to do so and how much?
I have been reading the tech sheets on filtering the mesh, but it would be good to get some real world input.
Thank you.
https://qualityforum.zeiss.com/topic/3545-advice-on-filtering-mesh/
Hi Brad,
Daniel from our training department has created an "It's a Hack" episode where he shows how to easily edit a mesh via thinning and smoothing.
https://www.youtube.com/watch?v=L_FmMB2zO7c
Unfortunately, it's not possible to specify exactly how much and how you need to filter. It depends a lot on how much information you can lose, what tolerances you have etc...
I hope this information helps you for now.
Best regards
Lukas
