speed of exporting stage data of .csv format
When I export 49 stage data of three elements into csv file, the process time is extremely slow, around 5 mins per stage file. Is there any way to improve it?
Si
Hi Si,
There are a few properties which can cause a slower working in the SW. Most of them are Hardware properties such as export speed.
The only thing you can do in the SW is to reduce the decimal places or reduce the stages. So that you receive a smaller filesize.
Greetings, Ivan
Hi Ivan
Thank you for your reply. In fact one csv file is only around 2 MB. And when I try to export xml file also with all stage data, and the size is around 237 MB, and the process time is only around seconds. Do you have any idea what happened?
Si
