Changing required alignments script
Keywords:
Name                                          | Description                                                           | Type
alignment                                     | Alignment                                                             | Tom::Traits::CADAlignmentResult
alignment_at_calculation                      | Required alignment for calculation                                    | Tom::Reference
seems the alignment_at_calculation is a 'Reference'. I'm having trouble changing it using python.
Here is where I am at right now...I can't see to find any syntax to change the alignment_at_calculation.
import gom
gom.script.sys.recalculate_project ()
for i in gom.ElementSelection ({'category': ['key', 'elements', 'part', gom.app.project.parts['Part'], 'explorer_category', 'actual', 'object_family', 'geometrical_element', 'type', 'section']}):
    x = i.get('name')
    print(x)
    print(gom.app.project.actual_elements[x].alignment_at_calculation)
print(gom.app.project.actual_elements.__doc__)
Hello Tim,
here I recorded the change for "Plane 1" first, and then set the alignment per script for "Plane 2":
# -*- coding: utf-8 -*-
import gom
#gom.script.sys.edit_properties (
#	data=[gom.app.project.actual_elements['Plane 1']],
#	elem_alignment_ref={'alignment': gom.app.project.alignments['Local Best-Fit'], 'alignment_can_be_used': True, 'rbmc_valid': False})
	data=[gom.app.project.actual_elements['Plane 2']],
Nanno
