[Go...] Posted January 23, 2024 Share Posted January 23, 2024 Hello all, Do you know is there a way to merge two volume from two CT scan in Zeiss Inpect Xray 2023 ? Best regards, Sylvain Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/ Share on other sites More sharing options...
[Lo...] Posted January 25, 2024 Share Posted January 25, 2024 Hi, are you asking to combine two scans of a Metrotom system or do you want to merge two volumes after importing them from already existing files? In the first case ZEISS INSPECT X-Ray 2023 offers the functionality of a multi-level scan by enlarging the box for the reconstruction area. The latter case is not supported by the software right now. Best, Lorenz Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/#findComment-10201 Share on other sites More sharing options...
[Go...] Posted January 30, 2024 Author Share Posted January 30, 2024 Please sign in to view this quote. I need to merge two volumes after importing them from existing files ... The scans were done on a Bosello Max and the 2D images were imported through a script into the reconstruction function of Zeiss Inspect X-Ray 2023. Thanks for your answer. Best regards, Sylvain Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/#findComment-10270 Share on other sites More sharing options...
[Na...] Posted February 17, 2025 Share Posted February 17, 2025 Hello, I'd like to inform you that this feature is in INSPECT X-Ray 2025. Nanno Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/#findComment-126614 Share on other sites More sharing options...
[DW...] Posted February 17, 2025 Share Posted February 17, 2025 Please sign in to view this quote. Can you polygonise one of the volumes, then actual mesh to CAD, align the CAD to the globals, and then align the volumes to the "CAD"? Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/#findComment-126628 Share on other sites More sharing options...
[Br...] Posted April 24, 2025 Share Posted April 24, 2025 Please sign in to view this quote. Hi Nano, is 2025 an available DL? Have current SMA, have not seen 2025 as an option, currently running 2023 Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/#findComment-130963 Share on other sites More sharing options...
[Na...] Posted April 25, 2025 Share Posted April 25, 2025 Hi Brian, you can download the Software from here: https://portal.zeiss.com/download-center/softwares/imt Please also make sure to request a license update. Link to comment https://qualityforum.zeiss.com/topic/3587-volume-merge-with-zeiss-inspect-xray-2023/#findComment-130999 Share on other sites More sharing options...
