Export using currently opened project parameters
Hello,
I would like to use the currently opened project parameters like name of the project and path of the project. ( eg.: name: New_project 1; path: C:/Users/.../Desktop )
How can I implement these in my script? This is not in Kiosk just an user-defined script.
Best regards,
Máté Tömöri
The following code may be helpful:
# -*- coding: utf-8 -*-
import gom
import gom_utils
import os
project_file = gom.app.project.project_file
print (project_file)
print (os.path.dirname (project_file))
print (os.path.basename (project_file))
There could be filename and Operating System constellations where this approach wouldn't work, but usually this  approach is sufficient enough.
Hope this helps?!
Regards
  • 2 weeks later...
  • 2 weeks later...
Just an additional comment for more general access to project parameters:
In the script editor hit the F2 key and select "Object group: Project -> project -> ..." in the pop up dialog.
I am quite sure this is what Bernd did to get "gom.app.project.project_file".
