[In...] Posted February 7, 2024 Share Posted February 7, 2024 Just started getting to know the T-SCAN hawk 2 & ZEISS INSPECT. I realise that the button (main trigger button to start the scan) on the T-SCAN hawk 2 is in place so that there is no need to operate the software separately on a laptop. However, in reverse, I was wondering if there is an option / method to operate the start of the scan on the software without the use of the button? Ultimately eliminating the physical function of the button. By modifying / adding on to the Python script? Link to comment Share on other sites More sharing options...
[Se...] Posted January 17, 2025 Share Posted January 17, 2025 (edited) Hello Please sign in to view this username. I’m working on an automation script for Hawk2 as well, and I just happened to come across this post. You can use gom.script.sys.tscan_hawk2_scan(timeout=10) to start a scan and the timeout parameter to specify when the scan will automatically stop. However, I have an additional question: is it possible to toggle the scan on and off I want? I used .__doc__ to check, and it seems that the timeout parameter is mandatory. Sometimes, I can’t precisely define the scan time because each workpiece is different. I hope someone can share their suggestions. Edited January 17, 2025 Link to comment Share on other sites More sharing options...
[Li...] Posted October 11, 2025 Share Posted October 11, 2025 Please sign in to view this quote. Dear Sean Have you fixed this problem?We have met the same problems these days. The SCAN can not be switched on and off as we want when we use gom.script.sys.tscan_hawk2_scan(timeout=10) Link to comment Share on other sites More sharing options...
