[yo...] Posted February 15, 2024 Share Posted February 15, 2024 Error MCADImport-0051: CAD converter message : Cannot import the file: API has crashed. How can I fix? all .stp file is cannot import. Link to comment Share on other sites More sharing options...
[Be...] Posted February 15, 2024 Share Posted February 15, 2024 Hi, in this case you have to contact your local ZEISS partner and you must supply your CAD data (confidential) for a deeper investigation. Regards, Bernd Link to comment Share on other sites More sharing options...
[Eg...] Posted March 25, 2024 Share Posted March 25, 2024 I have the same, suddenly from last week use to now on 25 March 2023. I use the old GOM-Inspect-V8_Hotfix_10 application to import STP and export to STL..... same here "error MCADImport-0051:CAD converter message: Cannot import the file: API has crashed" I have restarted computer... still the same. Run it on DELL inspiron with NVidia Link to comment Share on other sites More sharing options...
[Xi...] Posted March 26, 2024 Share Posted March 26, 2024 Please sign in to view this quote. Have you solved this problem? My software also has the same problem ( version, V8.5) Link to comment Share on other sites More sharing options...
[Na...] Posted March 26, 2024 Share Posted March 26, 2024 Hello, please use this workaround. "Current Software" means the free version of Zeiss Inspect 2023: Use the current GOM Software Version for importing a CAD file. Neutral CAD formats like STEP and IGES can be imported into the free GOM Software. In the Professional Version of the GOM Software native CAD formats can be imported as well. Create an actual mesh via: Operations / CAD / Convert CAD to Mesh and use therein the option CAD/CAD comparison. In doing so patch borders will be kept. Export this mesh as g3d file. Import the g3d file per drag and drop into a former GOM Software. Convert the actual mesh to CAD. Finally a CAD body in a former GOM Software is created. Link to comment Share on other sites More sharing options...
[Xi...] Posted March 27, 2024 Share Posted March 27, 2024 Please sign in to view this quote. FYI: The following content is from a log file in C:\ProgramData\gom\log ------------------------------------------------------------------------------------------------------------------- CADImport Log #1 Wed Mar 27 11:39:12 2024 client: 8.0-10 Build 2015-07-27 level 1 - Wed Mar 27 11:39:12 2024 CADImport[Client]: [2024-03-27 11:39:12] GOM-Module-CADImport-7980 CADImport[Client]: [2024-03-27 11:39:12] server started (pid 6932): D:\Program Files\GOM\V8\bin32\\cad-converter\gom_cad_server.exe CADImport[Client]: [2024-03-27 11:39:12] connection: io: connection closed by other end CADImport[Client]: [2024-03-27 11:39:12] connection: write: io failed in attempt to write 1 bytes CADImport[Client]: [2024-03-27 11:39:12] error in remote call of function #3: 22 (connection closed) CADImport[Client]: [2024-03-27 11:39:12] pid 6932: process terminated with exit code -1073741819 CADImport[Client]: [2024-03-27 11:39:12] server stopped ------------------------------------------------------------------------------ server: 8.0-10 Build 2015-07-27 level 1 - Wed Mar 27 11:39:12 2024 CADImport[Server]: [2024-03-27 11:39:12] GOM-Module-CADImport-7980 (pid 6932) CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: constructor start CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: constructor end CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: api constructor start CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: evolpath = D:\Program Files\GOM\V8\bin32\\cad-converter CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: ctusrpath = C:\Users\Administrator\AppData\Local\gom\tmp CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: api kernel NOT initialized CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: api-version : CADImport[Server]: [2024-03-27 11:39:12] cad_converter.cpp: api constructor end ------------------------------------------------------------------------------ Link to comment Share on other sites More sharing options...
[Na...] Posted March 27, 2024 Share Posted March 27, 2024 Hello, with this error please stick to the official workaround: https://techguide.zeiss.com/en/gom-software-2021/article/how_to_get_cad_data_into_old_gom_software.html You may contact your local distributor/support with problems. Maybe you are allowed to upgrade to a newer version. Again, please get in contact with your distributor. Nanno Link to comment Share on other sites More sharing options...
[ni...] Posted March 27, 2024 Share Posted March 27, 2024 (edited) bonjour, pour le problème de licence expirée (MCADImport-0051) quand il est impossible d'importer les CAD STP ou IGS, il suffit de reculer l'horloge du computer d' un an ou plus, et il est possible importer les CAD. Edited March 27, 2024 Link to comment Share on other sites More sharing options...
[学恭...] Posted April 19, 2024 Share Posted April 19, 2024 Can there be a patch to fix this? Link to comment Share on other sites More sharing options...
[Du...] Posted June 11, 2024 Share Posted June 11, 2024 You also have to watch in which CAD software the CAD was exported in. Ive noticed that IGES files import in all GOM software's regardless the CAD Software used to create and export the CAD. I've noticed that CAD Software newer than 2021 using DEFAULT setting for and CAD File extension (minus IGES) to export a CAD will not import into my 2017. it will however import into the newer 2021 and up ZEISS Inspect. So be mindful of the CAD Software creating the export. Link to comment Share on other sites More sharing options...
[Ja...] Posted June 13, 2024 Share Posted June 13, 2024 this looks to me like issues with attempting to import .stp and .igs files into much older versions of software ..say v8 . There was a licence relating to that import in these older versions controlled by date..it is very likely this date has passed and the licence doesnt work anymore , hence the requirement to follow the workaround gievn for older software. Im not at liberty to say as i dont work there anymore but honestly i would not expect it reasonable or probably even possible for the dev team to patch or fix this licence issue. The likelt way forward in the end is to use the workaround or use a later version of software Link to comment Share on other sites More sharing options...
