How to create a common-datums?
Hi,
creating a common datum works almost the same way as creating separate datums. In the Create Datum System window, instead of selecting one element for a datum, simply select several elements or create several fitting elements. The software then automatically calculates a common datum.
For more information, you can also take a look at the following TechGuide article:
https://techguide.zeiss.com/en/zeiss-inspect-2023/article/cmd_gdat_create_datum_system_nominal.html
Best regards
Lukas
